I agree, I’ve had great luck with CNHL’s. Whatever you choose, measure the size of your battery tray and get the biggest and highest MaH brick that will fit.So what you want seems to be higher MaH, Milliamphere/Hour, batteries. MaH is the storage capacity of any given battery but be aware most listed MaH's are inflated. There have been testes conducted here by others that proved this. But those tests also revealed a hidden gem. CNHL seems to be one of the best bangs for your buck. Consistently in the neighborhood of their stated specs where some well knowned expensive brands have been far off. Check them out
