GKA Rocker upgrade
Motorhead419
Installed the GKA rockers with Losi ends and 110mm HR limiter straps..Titanium 5x35mm Allen bolts. Avid bearings
Looks really clean. Are you using stock spring cups? Also, do you have any issues with the straps clearing or getting pinched by the springs?
Stock cups so far...straps look good as far as pinching..had to use longer shock screws and shims under the straps..
