Kraton Gathering information from this forum. Decided to do an overbuild of a Kraton EXB 6S. Slapped on PPS motor mount and squeeze in a 5687 Hobbywing.
SniperGT-15
  1. Felony
  2. Fireteam
  3. Granite
  4. Infraction
  5. Limitless
  6. Kraton 6s
  7. Kraton EXB
  8. Mojave
  9. Mojave EXB
  10. Outcast 6s
  11. Senton 3s
  12. Talion EXB
  13. Typhon 3s
  14. Typhon 6s
  15. Typhon TLR
  16. Vendetta
  17. Vorteks
  18. Infraction 4x4
Gathering and learning from this forum. Decided to do an overbuild of a Kraton EXB 6S. Slapped on PPS motor mount and squeeze in a 5687 Hobbywing 1100kv just to see if I could. Well, it worked and now I have an 8s system inside an 6S body šŸ˜‚
Nice! To claim your Build Thread Contributor badge, click on your name top rightā˜ļøand go to "account details". Scroll to the bottom and paste the link to this thread in the address bar into the following field:
Gathering and learning from this forum. Decided to do an overbuild of a Kraton EXB 6S. Slapped on PPS motor mount and squeeze in a 5687 Hobbywing 1100kv just to see if I could. Well, it worked and now I have an 8s system inside an 6S body šŸ˜‚ View attachment 301706
How did it work out? I have a HEAVY M2C'd K6 that overheats every motor I've tried in it. From a 1650kv 4092, 1250kv 4092, and two Spektrum 1250kv 4685's over 200 degreesF. Ran 6s on all the motors, the 8s on the 1650 and 1250 4092's. I haven't tried running the 4685's on 8s. On 8s both ESC and motor ran a little cooler, but not near enough. It mostly benefited the ESC. I don't run it top speed either, as I don't have the room. Have run the 4092's at an 18t pinion, and the 1250kv 4685 Spektrums with 23t. Would probably take me a 2-3 months to gather enough money for this setup. I'd get the PPS knockoff to save a bit. I'm super limited on money compared to most hobbyists here. Is it worth it, or should try my overheated 4685's again on 8s?
Itā€™s been a pretty nice setup. Granted I only drive it in mild climate and I have 3 game changer style fans running on a separate 3s battery to keep temps down.
