SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
60k in the Front. I usually keep the rear identical to the front when closer to stock Thin oils. But for hard bashing in wide open fields, doubling up the Front CST compared to the Rr, works out nicely. The rig will liven up for sure. Bringing the Center CST up considerably over stock, also keeps power to ground much better. Less diff bleeding at the rear results. Dramatic difference over stock with 60kFr/500k/ 20-30k Rr. This is commonly done. Tires will also last longer.
Use your temp gun to check the center diff temps and the Fr. and Rear Output cups. Center will get hottest normally. Why I recommend the Arrma Metal diff. option part. Or the Center Plastic stocker can literally melt into a molten lump of Metal/ plastic, Oil will turn to a Tar. Been there, when Center diff reaches as high as 250F. If your Fr or Rr Cups are getting Very hot, the diffs are underfilled and/or oil is just too thin. The Shimming may be too tight, or you have an impending failure of the diff sat and sun gears or Diff Pins. (Bent)
The Diff pins dimensions are listed as 2.25 x 9.8mm, But if you use your Caliper, they actually are slightly different. Both Length and diameter.
So use your actual caliper measurement when sourcing HS Drill bits or Blank ones. Chamfer the ends smooth. If left sharp and square, will also ruin the Sun gear quickly.
FWIW, I use only Mugen Seiki gear shims as replacements. ( E02026) Sometimes right out the box when going over the new diffs with the thicker oils. Or the stockers will wear out quickly, then the gears get all jacked up quick. They are too thin and bend and cone out fast. Gear alignment suffers. I like my diffs setup tighter when new. They break-in and loosen up within a few packs. The Oil will turn a silvery color as they wear in. Normal for these Arrma cast metals. Use fresh automotive grease on the Main and Input gears after verifying the shimming on the main gear side of the diff within the Bulkhead.
Like I mentioned above make sure to use some grease on the 2 Output cup shafts before inserting them into the diff's carrier. There is a notched Groove on the output shafts, this is where you concentrate a thin film of grease before inserting them. The notch holds/retains the grease there.
https://www.amainhobbies.com/mugen-seiki-differential-washer-set-muge0206/p3241.
https://www.arrma-rc.com/en/product/metal-diff-case/ARA220050.html
https://www.arrma-rc.com/en/product/aluminum-center-diff-set-50t-200k/ARA311118.html ( Complete Center diff with Spur gear)
>>>>>> This is where most of us get Arrma parts cheapest.
Complete Center Metal diff below:
https://jennysrc.com/collections/fi...blx-center-differential-50t-spur-gear-ara7618
This is a take off part from a FT, which comes with a Center metal diff out the box. Stock oil in it is 300k according to Arrma. But I bet it will also be low on oil. Arrma is cheap with their oil. Like my FT and all 6s rigs were.
But I will completely disassemble this and use Mugen Shims and 500k cst right out the gate running.
Checking the ESC, Motor and lipo temps are the priority.
Just that also checking drivetrain temps in other key areas can also reveal impending failures. Even worn, dirty or Unlubed BB's can cause diff failures FWIW.
Good luck.
Popping rear dog bones is a result of Poor Shock Droop and/or Shock Preload settings. And just driver error for the most part. Good to setup the Arms so they are all Level to the chassis, with body and lipo in place. At Full running weight.I've been planning to make a set that are just about 2mm longer than stock, so the axles have less tendency to pop out when the suspension is at full compression. Making a set of drive cups looks like a doable project. I've got a vacation coming up.
I never thought to check the temps on anything. I should poke around with a temperature gun and see how hot things are getting.
Good luck.
