Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
Thank you!! Exactly what I needed to know.For any 3s/4s Arrma you need these parts:
https://www.arrma-rc.com/en/product/center-brace-pin-2/ARA320529.html
https://www.arrma-rc.com/en/product/center-brace-mount-set/ARA320528.html
https://www.arrma-rc.com/en/product/center-brace-rubber-dampers-3/ARA320530.html
https://www.arrma-rc.com/en/product/center-brace-connectors-2/ARA320531.html
https://www.arrma-rc.com/en/product/cap-hd-screw-m3x10mm-10/ARAC9711.html
https://www.arrma-rc.com/en/product/nylon-nut-2.5mm-4/ARAC9761.html
For short wheelbase models (Granite, Vorteks) you want the 200mm center brace bar from the Outcast 4s
https://www.arrma-rc.com/en/product/center-brace-bar-200mm/ARA320533.html
For long wheelbase models (Senton, Big Rock) you want the 240mm center brace bar from the Kraton 4s.
This length will also fit a Typhon chassis, but I've been told the center brace bar doesn't fit under the low Typhon body.
https://www.arrma-rc.com/en/product/center-brace-bar-240mm/ARA320532.html
In the 4s Outcast and Kraton, the center brace mounts are held in place by the 4s body mounts. I don't think you need the 4s body mounts though. There are other ways to hold them in place. Some drill holes for screws. I wrapped Gorilla tape around the 3s body posts to make them thick enough to hold down the center brace mounts. (This isn't a concern in the Vorteks, since it has the center brace mounts integrated into the shock towers.)
