- Kraton 6s
- Outcast 6s
I know there's loads of threads on here debating all the different kinds of fans, different size, different material, different rpm, different voltage etc, but i need to know the real basics, dumb it down for me.
So none of my RC cars have ever came equipped with a fan, other than the OEM one built into the ESC. Mine were all older 6s versions of arrma cars before fans came as standard.
I would like to fit fans to the motor to prolong its life. It's a BLX185 ESC and motor running 6s, and i don't want to have to run them off of a seperate battery.
1. - Will a single fan be sufficient on the motor?
2. - Where do you plug the fan into?
3. - How many fans/amps drawn before a separate battery is required?
Thanks for any help, i've no experience with aftermarket fans.
