Agree with above. Also it appears that pinion gear is shot and will continue to strip new spur gears.You want as much engagement width wise as you can. Meaning the spur gear should have full coverage with the pinion. From the pic looks like it was a little short. As far as mesh on 32p and mod1 gearing I use 24# copy paper. Take a strip and feed it into the gearing. Force the two sides together and tighten up. Rotate the gears back so the paper comes back out. Over time you start to get a sense of the space between the gears. It should have a very very small amount of play in the mesh. I would also recommend setting the slipper correctly. If it's too tight you will strip gears and pop driveshafts.
From the looks of it yours was too loose.
OK thanks I just did the slipper but I'm going to redo it again to be safe and I've heard of that paper trick I just have not tried that yet but I will make sure to this timeYou want as much engagement width wise as you can. Meaning the spur gear should have full coverage with the pinion. From the pic looks like it was a little short. As far as mesh on 32p and mod1 gearing I use 24# copy paper. Take a strip and feed it into the gearing. Force the two sides together and tighten up. Rotate the gears back so the paper comes back out. Over time you start to get a sense of the space between the gears. It should have a very very small amount of play in the mesh. I would also recommend setting the slipper correctly. If it's too tight you will strip gears and pop driveshafts.
Also, you could check if the aluminum motor mount is bent. That would cause issues.OK thanks I just did the slipper but I'm going to redo it again to be safe and I've heard of that paper trick I just have not tried that yet but I will make sure to this time
