Or lets say less wheeliesI put Copperheads on my Outcast and vise versa. Can't say if they go faster on short distance.
No still wheelie like hell!Or lets say less wheelies
Yeah, This is a commonly asked question as which one to get. You already know they are two different animals.Ok great now the decision is even harder.....got all the necessary for a 4x4 and even saved for the 6s version but now it is Kraton or Notorious. I like the kraton to go fast and some stunts and stable while also looking at the notorious for mice wheelies with less effort stunt more easy and still fast. The query is getting a Kraton and get bored doing the same thing in tarmac or else get a Notorious and get board with all the wheelies and need longer distance to go fast????
The dilema of the year lol
150 in the center dif helps to stop wheelies to but makes flips trickyFor less wheelies you can try thicker rear shock oil and lower front / higher back with the preload (and overall lower), plus thin center diff oil.
I got both at the same time because it was hard to decide, so problem solved. I can say if you decide on one, you will probably consider getting the other in time.
You will not get bored with the Kraton, I'll assure you. This is the one I'd also recommend. It al depends on your intentions with each. My Kraton is my go to, I use the OC in smaller areas and around the house for ramp jumps. Its harded to control especially at speed, whereas the Kraton is much more predictable.
If I were to only have one, it would be Kraton hands down. Good luck with your decision. ??
Use 1/4" plywood instead of 1/2". 1/4" flexes a bit when you hit and if the ramp doesn't have a nice curve to it, it's going to be harsh to hit at a decent speed. 1/2" will be like hitting a wall, but the give that 1/4" has will soften the hit and also be less of a lip/ridge where it meets the ground.Wish i could get bought but its already out of budget to get a car that price but I know through experience if no parts exist its like u bought a car for once. Hopefully it will last long.
seeing again your comment part of your comment agian " My Kraton is my go to, I use the OC in smaller areas and around the house for ramp jumps" I think i will purchase the Notorious as most of the areas i will be at are always small areas and will create a small foldable ramp https://www.instructables.com/id/Quick-and-Easy-Folding-RC-Ramp/ for stunts so......will make some research and hit the button
Thanks again
Can't go wrong with either. ?Wish i could get bought but its already out of budget to get a car that price but I know through experience if no parts exist its like u bought a car for once. Hopefully it will last long.
Thanks again
