FH-RC
- Granite
Hello everyone,
I would like to ask you guys on your shock setup and how plush you have set your Granites/Big Rocks suspension for big air?
Or in other words:
From what heigth can you drop your vehicles before you get chassis slap?
My own setup:
I run my Granite with the ZD Racing shocks (Link) with 6-hole pistons, the stock ZD springs, little to no preload and 1000cst (~75wt) on RPM arms at the outer, more stiff hole position. Normally, I can drop my Granite from about 30cm before the chassis slaps onto the ground. Hence, I would like to know, if for example the Kraton/Mojave/Typhoon shock combination would make it more plush, so I can drop from higher heights before the chassis slaps.
I know, chassis slap is normal and a must if you don't want to break the suspension (piston out the shock cap is no good), but I send the Granite up to 6m into the air at my local dirt park. So, this means that I basically drop this thing from 5,7m into the ground without damping
Or in other words:
My own setup:
