Saltystevo
True if you cut the lead off. But if you simply unplug the red wire from the black plug and tape it up you wouldn't have to worry about warranty issues.Yes, disconnecting the red wire does accomplish the exact same thing as the harness. But with the harness the esc remains factory. If you clip the red wire and and the esc fails and send it in for warranty, they can always come back and say that clipping that wire caused the failure. Chances are slim but I see it as leaving a door open for them to reject the claim.
And correct me if I'm remembering wrong but doesn't the factory bec bug out occasionally and short out people's electronics?
It actually might be even safer to not use the harness if that was the case, no?
