Culminate6391
I know the recommended is the 1717 1650kv but I have a 1512 1800kv on hand already and was going to build up a kraton roller. What issues or problems am I going to see with the 1512?
Application Guidelines: | Ideal for 1:8 scale off-road and on-road vehicles as well as 1:10 scale 4WD SCT up to 9lbs. |
I have an extra 1515 on the shelf. PM me if you’re interested.I'll probably bolt it up just to see what happens...but will likley go to the 1717 with something like a 18 or 20t spur.
I assume you meant pinion. I have a K6EXB with a 1717 1650KV motor in it and it's probably going to get a bit toasty with a pinion of that size without some fans for cooling. I run a 16T in mine and it seems to be a good balance and plenty fast for my taste. YMMVI'll probably bolt it up just to see what happens...but will likley go to the 1717 with something like a 18 or 20t spur.
