Mechanicos
- Fireteam
- Kraton EXB
Hi everyone, i am planning on buying the ToolkitRC M6D charger, it has decent wattage and can charger 2x batteries at once, it also gives the resistance of the cells. It looks ok.
https://www.toolkitrc.com/m6d
M6D input power is
Therefore the wattage i need is:
(3S) WATTS = 12.6V x 5.3A = 67WATTS
67W x 2 = 134watts
Then if you add inefficiencies etc, lets say i will need 200watts in total for the maximum i will charge for 2x 3s lipos.
However i cant decide on the power supply, first of all due to availability and secondly i was thinking that i may need an adjustable voltage PSU.
What do you guys think?
Shall i go with the SkyRC efuel 380w and be done with it?
https://www.skyrc.com/PSU/efuel380
M6D input power is
- Input: 7-28V@MAX30A
67W x 2 = 134watts
