RcSpeedFreak
Yes I’m pretty they do. It’s not really about the fact that the esc is sensored I just don’t like that it has to stick out. And if it used a traditional setup you would be able to unplug it.They sell a sensor cable that goes from their connection to JST if I’m not mistaken. As well, the app seems to be reliable. I haven’t seen many (if any) complaints on this forum about it and I personally have not had any issues.
You can unplug it if you wish and run any non-sensored motor and as mentioned above, there is an adapter pigtail for conventional sensored motors.Yes I’m pretty they do. It’s not really about the fact that the esc is sensored I just don’t like that it has to stick out. And if it used a traditional setup you would be able to unplug it.
What I meant was you can’t unplug it from the actual esc.You can unplug it if you wish and run any non-sensored motor and as mentioned above, there is an adapter pigtail for conventional sensored motors.
