- Tel Aviv, Israel
- Granite
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
- Voltage
Finished my dream Arrma truggy.
(Almost.. i still want to replace the electronics to a MAX8)
I wanted something close to what i would imaging a TLR Talion would be like, so i started with my EXB Talion and made these changes:
- V4 arms - much stiffer than EXB arms, better handling
- JConcepts front Kraton shock tower
- Basher Queen rear V4 Kraton shock tower, carbon fiber
- Fireteam shocks, planned to use the Typhon TLR delrin piston but i was surprised to find they already came with machined pistons.. while they are not tapered like the Typhon ones, they are actually look really high quality, and the shock movement is as good as it can be. 8x1.3mm rear and 8x1.2mm front (which is different than the spec of 1.4 rear.. but that what i got in mine so i don't complain as it what i planned to use anyway)
- shock oil - 450cst front, 400cst rear
- used the springs from the original Durango truggy shock setup, which is AR330384 for the front and AR330239 for the rear.
- Rear wing mount from a Typhon TLR (which comes with higher wing mount base)
- Durango wing which i found on ebay
- front body mount from a limitless
- JConcepts F2 bruggy body
