Mojave Built a mojave for a friend
calebgilmore
  2. Infraction
  3. Kraton 8S
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Senton 6s
  9. Talion
  10. Typhon 6s
  11. Vorteks
  12. Voltage
Knocked a mojave out for a friend looking to get into one on a budget. Dipped into my spares to help get it done. I need a real job building trucks 😂 second build for someone. He sold me a 6s senton with the castle esc/2200kv motor in it and he wanted me to put it in the mo to get it going but will upgrade later. I would have definitely put a beefier combo in but it’s a start!
Also had to email horizon about the exb upper hinge pin block I had bought that was missing the drilled/tapped holes for the keeper screws 😂
This truck has exb shock towers/front upper rear hinge pin block, just bash it +2mm hex and wheel nuts, exb shock stand offs, a set of methodrc wheels and worn vitavons on hyrax. I had a stock k6 ebs servo I was going to use on a small tire build I threw in. Tekjo gaskets on the cups and bulkhead to chassis as well.
I see you did a Solid. 👊
Can tell it brought MoJo'y to you and your buddy. 🍺🍺
Great job on the Mojo, you should get a build thread banner. 👍
Yes.
This would be a great Build Thread ,add this thread link to your profile and get your build banner!
