- Catskills, New York
- Kraton EXB
- Mojave EXB
- Typhon 3s
- Typhon 6s
- Voltage
Arrma 6S Custom (Mojave, Kraton, Typhon)
Built for Grass Field Running and some mild bashing. Mostly running fields as fast as a F'in can.
Fastest im getting over grass is in the 70's on a good day, right field and conditions.
Id like to break 90 and get as close to 100 as I can, swapping out the ESC and Motor. Fix the rest as it breaks. LOL
I thought maybe 8S. The ESC's and motors are a bit big for this truck but possible.
Im afraid it'll just over power it and rip the Arrma parts up. But I can also run it on 6S most of the time. Then some 8S Blasts when conditions are right. Baby it some.
6S is likely better. More reliable. But I need Power and Quality. And as Jeremy Clarkson reminds us, More Power! The stock ESC bogs and disappoints. I can also start with a very good ESC and kill the stock motor some then replace it.
Ive looked at all of them and my head is spinning off!
Whats the most appropriate ESC and Motor Transplant for Big Bad Wolf?
Max6 ESC looks nice.
But what motor?
Looking forward to Spring!!
As this builds stands now.
Weighs in at 14 lbs (6372g)
with an 8000mAh 6S Lipo its16.3 lbs (7377g)
- Arrma 6s EXB - ESC Spektum Firma 150 Smart
- Arrma 6s BLX - Spektrum Firma 4074 2050kV Brushless w/sink
- Arrma 6s EXB - 18t or 23t Pinion Gear (steel Mod 1 5mm Safe-D)
- Mojave EXB Chassis (7085 aluminum)
- Kraton Front Open Dif (200cst) (43t/10t)
- Typhon Center BLX Open Dif (1Mcst) (50t Spur)
- Kraton Rear BLX Open Dif (500cst) (43t/10t)
- Typhon 6s V5 BLX - Towers Front/Rear Shock Towers
- Kraton 6s EXB - Front Shocks, 85mm 1.09N/mm (6.2lb/in) Springs
- Kraton 6s EXB - Rear Shocks, 95mm 0.87N/mm (5.0lb/in) Springs
- Kraton 6s EXB - Suspension A-Arms, Hubs 17mm Hex, Steering Caster Blocks Axle Carriers.
- ANNIMOS 35KG Digital Servo 7.4V
- Mojave/Kraton EXB mount braces and center brace.
- Kraton 6s EXB Wing
- Arrma EXB Super Basher Front Bumper.
- RPM Front Bumper and Arrma Skid Plate on the rear.
- Arrma dBoots Back-Flip MT 6S, 172m X 97mm
- Typhon 6s V5 BLX - Body Shell
- HOOVO 6S 22.2V LiPo Battery 8000mAh 100C
- HOBBYMATE Flysky FS GT5 RC Transmitter with FS BS6 Gyro Receiver
But what motor?
