Lorenzo fortune
- Typhon 6s
Stick a plaster on it and go ripple up some more tarmac ,rig looks sweet
Only way to repair road rash ,would be to do some body work .If the scratches are not to deep ,you could try wet sanding them down.anything left over if they still bothering you then a light body filler could be applied then more sanding and feathering it all out then primer .more wet sanding then paint ..but since this is all on the out side of the shell ,you either make this cover just as a shelf queen or drive with it carefully...which i doubt you will lol.I’m still a noob in training, and was wondering if there was an easy way to fix this road rash. Easier than stripping away all of the paint and repainting it as I training, and was wondering if there was a easy way to fix this road rash. Easier than stripping away all of the paint and repainting it as I have never done either. Thanks for the input…appreciate it!
I suppose you love .must be your color.
When you turn your front wheels to the left or right don't the back of the tires rub the back of the fender flares ,looks like the cover should be pushed forward a little.they look very tight against the back wheel wells.sorry meant to say looks like you need to bring back the body cover a little.
The body cover needs to get pushed back a few mm . maybe like 4 or 5 mm back. You could elongate the post holes and then use thicker posts.or cut the back side of the wheel wells a little..a little trim would be the easiest way.The Nismo body isn’t a good fit in the front. You can see it on the wheel wells.
If this is your shelf queen cover then I'd leave it alone .
Well it's on you ,I mean if it turns fine then don't worry about it but if they rub then you might start seeing damage to your tires and the cover..I thought you said you had to covers ,one you ran and one you kept for showI don’t really have any shelf queens. No one is in my basement. lol. So I’ll try trimming the wheel wells. If I F it up? Maybe I’ll try the NASCAR body!
Nobody sees mine either except for you guys.I don’t really have any shelf queens. No one is in my basement. lol.
Having a second, well kept "shelf queen" body allows me to bash up the other body without worrying. Does that make sense?A shelf queen doesn't allways mean it's on a shelf for showing off to people .it can also mean it's just a Rc that you don't use and you want to keep it nice unused.
Makes perfect senseNobody sees mine either except for you guys.
See that looks sweet ..cover is doing it's job and you can see everything under it.great way to show off electronics and any custom work and any mods .One of the reasons I don't do perfect paint anymore. Its only perfect till the first time..... Then it's all pistivity.
One race season I didn't paint anything. TQ'd multiple A-main's too. Paint don't make em faster
Like Nike..JUST DO ITI have two Vette Bodies for running. I’ll see how my Infraction goes with the new side skirts. Vette too. I didn’t tape it down and it was just launching. So now I’m torn because I just can’t see myself being able to stop myself from making the GTR body fit and running it. So! As we say here? F it. It just looks way too sweet to not be ripping by me.
Damn, sorry about your crash. .well now it's back to building the other fun part of the hobby ..spend more mofo loot . can't wait to see you rebuildSkyline it is! I can move the posts back a little bit and we’ll see! Cause first run today and serious carnage on the infection.
