slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
That's a very good point and I have seen similar jigs that are indeed made from all aluminum which would defeat the purpose of heating up the bullets. This particular jig is made from a plastic like material where the bullets are held.
Also per the product details in the link provided: "Thermal Insulating Layer: Black thermal insulating layer surrounded by the holes, which can effectively prevent heat propagation"
XT150 connectors are another good selection for sure!
Sorry Slick but with regard to that particular jig @WoodiE has shown you are incorrect. That black area that you use for bullit connects is Bakelite. I have that precise jig and it is awesome and makes life much easier......there are many jigs that look like that which are aluminium and in which case your advice is 100% correct and people should keep away from them for the reasons your outline.....the one Woodie is showing is not one of those and works well.
Yeah my bad, as you can see from later posts when I looked at the picture it looked like it was all aluminum and I remembered someone saying not to get them because it takes forever to heat up your bullets. I should edit my to say to be careful when buying those as you don't get one that is all aluminum.
