- BigRock 4x4
- Kraton EXB
Well, thanks to Extreme Sports dudes here in Colorado, you can carry spring loaded knife since 2018. Reason being that if you get caught up in ropes parachuting, climbing, etc., you have a one hand solution to save your life. I'm totally on board with that! The limitation is that concealed (in your pocket) is limited to 3.5" and again I have no issue with that. Having said as much, here is my very well used OTF (Out The Front) Boker in D2 steel I use everyday in the factory. Way, way safer than the razor knives the factory gives us and I'll explain later.
Aha, first I wanted to see If I could post... Anyway, first question "What the heck? Aren't you worried about it stabbing you in the huevos?" Nope, because if you understood how a true auto knife works, it's safer than a Buck folder.... Which of one sort or another I've carried for 48+ years.
