fishycomics
As I had a wheelie bar from my Bison and cheetah, i do not use the vkar that much, here is my Mod. and down below will be some info on what I used and how I did it.
You may find the part I used online. here online here is a photo of it
photo host
I used angle Iron I had laying around as the plate was thin, stiff and perfect, just shy of making it one solid piece so that is what you'll need to slip in there.
upload pic
1 I measured and cut the amount needed. I filed to my liking nice rounded designs and may need some more shaping. I then drilled my holes. and assembled. Fit the first shot.
Here is what it looks like on
Skill level to do 1-5 3 between hard and easy. Time to do Under an hour, tools required. drill, bits, file, hack saw. hex keys or drivers. Painting optional.
Any questions just ask, Have not yet tested out due to a new car and waiting on my connections.
This Modification is done at your own risk and if a wider stance/wheelie bar is needed, change out the Bolt and inner shaft, the bolts on the wing are long enough to hold.
Here is a more solid fitted piece of metal out of a wall switch plate.
A test run video shall be added in the place of this sentence in bold
My conclusion shall be noted as well and replaced when I am with it completed
On that note why I did not spend for a R whatever or t bone I am happier with the one I got and looks a lot neater if asked "For me"
FISH
photo host
upload pic
FISH
