Arrma Kraton Manuals
Arrma Kraton Parts List
AR220029 - CENTRE DIFF SET 50T (1pc) S
AR220033 - CVD DRIVESHAFT SET 182.5mm (2pcs) S
AR220041 - F/R DIFF SET 43T SPIRAL (1pc) S
AR310427 - GEARBOX CASE SET (1pc) S
AR310428 - COMPOSITE CENTRE DIFF MOUNT S
AR310429 - SPUR GEAR 50T (1pc) S
AR310432 - INPUT SHAFT CUP (7x18mm) (1pc) S
AR310433 - DIFF CASE SET (1pc) S
AR310436 - DIFF GEAR SET (1 unit) S
AR310439 - STEEL DIFF OUTDRIVE (2pcs) S
AR310440 - PIN 2.25X9.8MM (6pcs) S
AR310444 - DIFF GASKET (3pcs) S
AR310446 - ALUMINIUM MOTOR MOUNT (Red) (1pc) S
AR310449 - ALUMINIUM WHEEL NUT 17mm (Black) (4pcs) S
AR310450 - BALL 3x7.8x8mm (4pcs) S
AR310452 - CVD REBUILD SET (2pcs) S
AR310458 - CVD DRIVESHAFT 141.5mm (2pcs) S
AR310459 - DOGBONE 139.5mm (2pcs) S
AR310460 - DOGBONE 135mm (1pc) S
AR310472 - DOGBONE 116mm (1pc) S
AR310473 - 12T MOD1 PINION GEAR (1pc) S
AR310474 - 13T MOD1 PINION GEAR (1pc) O
AR310475 - 14T MOD1 PINION GEAR (1pc) S
AR310476 - 15T MOD1 PINION GEAR (1pc) O
AR310477 - 16T MOD1 PINION GEAR (1pc) O
AR310478 - 17T MOD1 PINION GEAR (1pc) O
AR310479 - 18T MOD1 PINION GEAR (1pc) O
AR310480 - 19T MOD1 PINION GEAR (1pc) O
AR310481 - 20T MOD1 PINION GEAR (1pc) O
AR310482 - 21T MOD1 PINION GEAR (1pc) O
AR310483 - 22T MOD1 PINION GEAR (1pc) O
AR310484 - ALUMINIUM WHEEL HEX 16.5mm (Red) (2pcs) S
AR310497 - MAIN DIFF GEAR 43T SPIRAL (1pc) S
AR310498 - MAIN INPUT GEAR 10T SPIRAL (1pc) S
AR310590 - CVD AXLE 8x44.5mm (2pcs) S
AR310591 - WHEEL AXLE (8x45mm) (2pcs) S
AR320005 - BODY CLIP 6mm (10pcs) S
AR320169 - RADIO BOX SET S
AR320189 - COMPOSITE SIDE GUARDS (2pcs) S
AR320192 - BATTERY TRAY SET (1pc) S
AR320193 - ESC TRAY SET (1pc) S
AR320195 - ALUMINIUM TOP PLATE (Red) (1pc)
AR320196 - CHASSIS BRACE SET S
AR320197 - ALUMINIUM CHASSIS LWB (Black) (1pc) S
AR320215 - CNC ALUMINIUM WING BUTTONS (Red) (2pcs) O
AR320216 - CNC ALUMINIUM WING BUTTONS (Black) (2pcs) O
AR320217 - CNC ALUMINIUM WING POSTS (Red) (2pcs) O
AR320218 - CNC ALUMINIUM WING POSTS (Black) (2pcs) O
AR320273 - COMPOSITE CENTRE ROLL CAGE SET (1pc) S
AR320324 - ROLL TOWER MT TOP S
AR320335 - LARGE BENT BODY CLIP (BLACK) (4pcs) S
AR320347 - HD REAR WING MOUNT SET (1PC) S
AR330186 - ALUMINIUM RF SUSPENSION MOUNT (Red) (1pc) S
AR330194 - HINGE PIN OUTER 4x45mm (2pcs) S
AR330195 - SHOCK SHAFT 3.5x64mm (2pcs) S
AR330196 - ALUMINIUM FRONT HUB NUT (Red) (4pc) S
AR330197 - PIVOT BALL M6x14x35mm (2pcs) S
AR330199 - RUBBER SHOCK BOOT 36.5mm (Black) (2pcs) S
AR330200 - FRONT SWAY BAR 2.4mm (1pc) S
AR330201 - REAR SWAY BAR 2.7mm (1pc) S
AR330202 - BALL 3x7.8x10.5mm (4pcs) S
AR330203 - COMPOSITE SHOCK PART SET (2pcs) S
AR330204 - ALUMINIUM UPPER SHOCK CAP (Black) (2pcs) S
AR330205 - ALUMINIUM LOWER SHOCK CAP (Black) (2pcs) S
AR330206 - SHOCK BALL 3x6.8x6.3mm (4pcs) S
AR330208 - SHOCK BLADDER (4pcs) S
AR330211 - ALUMINIUM SHOCK COLLAR (Black) (2pcs) S
AR330212 - ALUMINIUM SHOCK BODY 16x51mm (Red) (2pc) S
AR330216 - BALL 3x5.8x10.8mm (4pcs) S
AR330217 - BALL 3x5.8x4.8mm (4pcs) S
AR330218 - FRONT UPPER SUSPENSION ARMS L (1pair) S
AR330219 - FRONT LOWER SUSPENSION ARMS L (1pair) S
AR330220 - ALUMINIUM FRONT SHOCK TOWER L (Black) (1pc) S
AR330221 - STEEL TURNBUCKLE M5x89mm (Black) (2pcs) S
AR330222 - ALUMINIUM REAR SHOCK TOWER L (Black) (1pc) S
AR330229 - ALUMINIUM RR SUSPENSION MOUNT (Red) (1pc) S
AR330230 - COMPOSITE BALL CUPS S
AR330231 - SHOCK MOUNT PIN 3x21.5mm (Black) (4pcs) S
AR330232 - SHOCK STANDOFF (4pcs) S
AR330239 - SHOCK SPRINGS: 84mm M (56.6gf/mm) (2pcs) O
AR330243 - RUBBER SHOCK BOOT 45mm (Black) (2pcs) S
AR330245 - O-RING P-3 3.5x1.9mm (Red) (4pcs) S
AR330249 - REAR LOWER SUSPENSION ARMS L (1pair) S
AR330250 - ALUMINIUM SHOCK BODY 16x63mm (Red) (2pcs) S
AR330251 - SHOCK SHAFT 3.5x75mm (2pcs)
AR330378 - ALUMINIUM FF SUSPENSION MOUNT (Red) (1pc) S
AR330379 - COMPOSITE SUSPENSION MOUNT SET (4pcs) S
AR330380 - HINGE PIN FRONT UPPER M4x46mm (2pcs) S
AR330381 - HINGE PIN LOWER 4x67.5mm (2pcs) S
AR330383 - SHOCK SPRINGS: 76mm S (73.6gf/mm) (2pcs)(*Replaced by TD330814[/URL] - SHOCK SPRING 75mm BLUE (73 gf/mm)(2pcs))
AR330384 - SHOCK SPRINGS: 76mm M (80.3gf/mm) (2pcs)
AR330385 - SHOCK SPRINGS: 76mm H (88.3gf/mm) (2pcs)(*Replaced by TD330816[/URL] - SHOCK SPRING 75mm RED (88 gf/mm)(2pcs))
AR330403 - COMPOSITE FRONT STEERING BLOCK (2PCS) S
AR330404 - REAR HUB (2PCS) S
AR340060 - ALUMINIUM STEERING RACK (Red) (1pc) S
AR340061 - ALUMINIUM SERVO HORN (Black) (1pc) S
AR340062 - STEERING HARDWARE SET (2pcs) S
AR340065 - ALUMINIUM SERVO SAVER HUB (1pc) S
AR340066 - STEEL STEERING POST 3x45mm (Black) (2pcs) S
AR340067 - STEERING BUSHING 6x10x3mm (4pcs) S
AR340071 - STEEL TURNBUCKLE M4x95mm (Black) (2pcs) S
AR340072 - ALUMINIUM STEERING PLATE A (Red) (2pcs) S
AR340073 - COMPOSITE STEERING BELLCRANK SET S
AR340074 - BALL M3x8x12.5mm (2pcs) S
AR340075 - BALL 3x6.8x6.3mm (2pcs) S
AR340122 - SERVO SAVER SPRING 12x20mm HARD (1pc) S
AR390101 - HOOK AND LOOP BATTERY STRAP (2pcs) S
AR390139 - ADS-15M V2 15kg WATERPROOF SERVO (Red) S
AR390141 - ADS GROMMETS (4pcs) S
AR390147 - ADS METAL GEAR SERVO CASE (Red) (1pc) S
AR390149 - ADS-15M V2 METAL GEAR SET S
AR390178 - BODY CLIP RETAINERS 1/8 SCALE (BLACK, 4pcs) S
AR390195 - MALE XT90 TO FEMALE T-PLUG CHARGING ADAPTOR O
AR390196 - FEMALE TO MALE JR 150MM SERVO EXTENSION O
AR390199 - BATTERY CONNECTOR XT90 (FEMALE, 2pcs) O
AR390200 - BATTERY CONNECTOR XT90 (MALE, 2pcs) S
AR390201 - MALE XT90 TO 4MM 'BANANA' PLUG CHARGING ADAPTOR O
AR390204 - FEMALE XT90 'LOOP' CONNECTOR O
AR390205 - BLX 2050KV BRUSHLESS 4074 6S MOTOR S
AR390211 - BLX185 BRUSHLESS 8TH 6S ESC S
AR406003 - KRATON 6S BLX PAINTED DECALED TRIMMED BODY (Black) (1pc) O
AR406004 - KRATON 6S BLX CLEAR BODYSHELL (inc. decals/window masks) (1pc)(*Replaced by AR406050[/URL] - KRATON 6S BLX CLEAR BODYSHELL (INC. DECALS/WINDOW MASKS)) O
AR406009 - KRATON 6S BLX PAINTED DECALED TRIMMED BODY (Blue) (1pc) O
AR406050 - KRATON 6S BLX CLEAR BODYSHELL (INC. DECALS/WINDOW MASKS) O
AR406053 - KRATON 6S BLX PAINTED DECALED TRIMMED BODY (GREEN/BLACK) S
AR406078 - KRATON 6S BLX PAINTED DECALED TRIMMED BODY (RED/BLACK) O
AR480001 - REAR WING 204mm (Black) (1pc) O
AR480002 - REAR WING 224mm (Black) (1pc)
AR480003 - REAR WING 204mm (White) (1pc) O
AR480004 - REAR WING 224mm (White) (1pc) O
AR510063 - SPLIT 5 SPOKE KRATON 6S MONSTER TRUCK WHEEL (Black) (2pcs)(*Replaced by AR550013[/URL] - DBOOTS 'COPPERHEAD MT 6S' TIRE SET GLUED (Black) (2pcs)) S
AR510064 - SPLIT 5 SPOKE KRATON 6S MONSTER TRUCK WHEEL (Black Chrome) (2pcs)(*Replaced by AR550013[/URL] - DBOOTS 'COPPERHEAD MT 6S' TIRE SET GLUED (Black) (2pcs)) O
AR510075 - SPLIT 5 SPOKE KRATON 6S MONSTER TRUCK WHEEL (Chrome) (2pcs)(*Replaced by AR550013[/URL] - DBOOTS 'COPPERHEAD MT 6S' TIRE SET GLUED (Black) (2pcs)) O
AR530050 - FOAM INSERT KRATON 6S MONSTER TRUCK M (2pcs)(*Replaced by AR550013[/URL] - DBOOTS 'COPPERHEAD MT 6S' TIRE SET GLUED (Black) (2pcs)) S
AR550011 - DBOOTS 'EXABYTE T 6S' TYRE SET GLUED (Black) (2pcs) O
AR550013 - DBOOTS 'COPPERHEAD MT 6S' TIRE SET GLUED (Black) (2pcs) O
AR550034 - DBOOTS 'MINOKAWA MT 6S' TIRE SET GLUED (Black) (2pcs) S
AR550035 - DBOOTS 'RAGNAROK' TIRE SET GLUED (Black Chrome) (2pcs) O
AR610006 - BALL BEARING 6x10x3mm (4pcs) O
AR610016 - BALL BEARING 8x16x5mm (2pcs) S
AR610017 - BALL BEARING 8x19x6mm (2pcs) S
AR610018 - BALL BEARING 15x21x4mm (2pcs) S
AR610019 - BALL BEARING 5x11x4mm (2pcs) S
AR702001 - CAP HEAD SCREW M2.5x8mm (10pcs) S
AR709003 - WASHER M3x8x0.5mm (10pcs) S
AR709024 - WASHER 3.5x12x0.15mm (10pcs) S
AR709025 - WASHER 2.8X6X0.5mm (4pcs) S
AR713009 - PIN 2.5x16.8mm (4pcs) S
AR713011 - PIN 4x73mm (2pcs) S
AR715001 - NYLON NUT M3 (4pcs) S
AR715005 - NYLON NUT M4 (4pcs) S
AR715008 - NYLON NUT M2.5 (4pcs) S
AR716010 - O-RING 19X1mm (4pcs) S
AR716011 - O-RING P-5 4.5x1.5mm (Red) (4pcs) S
AR721306 - BUTTON HEAD SCREW M3x6mm (10pcs) S
AR721308 - BUTTON HEAD HEX MACHINE SCREW M3x8mm (10pcs) S
AR721312 - BUTTON HEAD HEX MACHINE SCREW M3x12mm (10pcs) S
AR721316 - BUTTON HEAD SCREW M3x16mm (10pcs) S
AR721320 - BUTTON HEAD HEX MACHINE SCREW M3x20mm (10pcs) S
AR721322 - BUTTON HEAD SCREW M3x22mm (10pcs) S
AR721326 - BUTTON HEAD SCREW M3x26mm (10pcs) S
AR721412 - BUTTON HEAD SCREW M4x12mm (4pcs) S
AR721435 - BUTTON HEAD SCREW M4x35mm (4pcs) S
AR721440 - BUTTON HEAD SCREW M4x40mm (4pcs) S
AR722208 - FLAT HEAD HEX MACHINE SCREW M2x8mm (10pcs) S
AR722305 - FLAT HEAD HEX MACHINE SCREW M3x5mm (10pcs) S
AR722308 - FLAT HEAD HEX MACHINE SCREW M3x8mm (10pcs) S
AR722312 - FLAT HEAD HEX MACHINE SCREW M3x12mm (10pcs) S
AR722316 - FLAT HEAD SCREW M3x16mm (10pcs) S
AR722320 - FLAT HEAD SCREW M3x20mm (10pcs) S
AR722412 - FLAT HEAD SCREW M4x12mm (4pcs)
AR723312 - CAP HEAD SCREW M3x12mm (10pcs) S
AR723328 - CAP HEAD SCREW M3x28mm (4pcs) S
AR723410 - CAP HEAD SCREW M4x10mm (4pcs) S
AR724303 - SET SCREW M3x3mm (10pcs) S
AR724305 - SET SCREW M3x5mm (10pcs) S
AR724310 - SET SCREW M3x10mm (10pcs) S
AR724403 - SET SCREW M4x3mm (10pcs) S
AR724410 - SET SCREW M4x10mm (10pcs) S
AR724505 - SET SCREW M5x5mm (10pcs) S
TD330689 - ANTI-ROLL BAR FRONT 2.1mm WHITE O
TD330690 - ANTI-ROLL BAR FRONT 2.2mm BLUE O
TD330691 - ANTI-ROLL BAR FRONT 2.3mm GREEN O
TD330692 - ANTI-ROLL BAR FRONT 2.4mm YELLOW O
TD330693 - ANTI-ROLL BAR FRONT 2.5mm RED O
TD330694 - ANTI-ROLL BAR FRONT 2.6mm BLACK O
TD330695 - ANTI-ROLL BAR REAR 2.5mm BLUE O
TD330697 - ANTI-ROLL BAR REAR 2.6mm GREEN O
TD330698 - ANTI-ROLL BAR REAR 2.7mm YELLOW O
TD330699 - ANTI-ROLL BAR REAR 2.8mm RED O
TD330700 - ANTI-ROLL BAR REAR 2.9mm BLACK O
TD330778 - SHOCK SPRING 70mm BLUE (68 gf/mm)(2pcs) O
TD330779 - SHOCK SPRING 70mm GREEN (75 gf/mm)(2pcs) O
TD330780 - SHOCK SPRING 70mm YELLOW (80 gf/mm)(2pcs) O
TD330781 - SHOCK SPRING 70mm RED (85 gf/mm)(2pcs) O
TD330782 - SHOCK SPRING 84mm BLUE (52 gf/mm)(2pcs) O
TD330783 - SHOCK SPRING 84mm GREEN (57 gf/mm)(2pcs) O
TD330784 - SHOCK SPRING 84mm YELLOW (62 gf/mm)(2pcs) O
TD330785 - SHOCK SPRING 84mm RED (66 gf/mm)(2pcs) O
TD330786 - SHOCK SPRING 84mm BLACK (72 gf/mm)(2pcs) S
TD330814 - SHOCK SPRING 75mm BLUE (73 gf/mm)(2pcs) O
TD330815 - SHOCK SPRING 75mm YELLOW (80 gf/mm)(2pcs) O
TD330816 - SHOCK SPRING 75mm RED (88 gf/mm)(2pcs)
