- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
I've bought multiple tp motors from tp power usa.before I order a motor I reserch an compare probly more than most.they have alot of wrong info on there website.inaccurate info on premium products is BS.for instance this motor I'm looking at is a 5s motor?? Max rpm is 78000rpms .do the math an motor will take 22.5 v before max rpm.speedrunning on 6s volts will stay under 21volts on a run....
Also alot of there motor weights are wrong,have Seen many typos on there website..I expect accurate info when buying a premium product..
Research, research, then research some more to make sure your getting something that works to its best capabilities
