Kraton 6s Upgraded to 4s??
Chipz
Hey all, I brought a Kraton V1 and it running a Hobby wing XeRun XR8 Plus esc with Tekin T8 g2 2250kv on 4S, 16P/50S gears, 75kph. The Xr8 is 6s compatible but the Tekin T8 is only 4s recommended. So my question is why would some one pull the 6s system and install a 4s set-up??? Pros/Cons??
Thanks Chipz.
Because he ran it on 4s? Or ignored the 6s recommendation? He doesn't know what he's doing? Your guess is as good as anyones. :)
Looking at the 65000 max RPM spec for the motor, 6s will still be under that, so... I'd probably run it on 6s.
edit: some Googling confirms that people indeed run it on 6s!
edit 2: I don't see a sensor wire in there... both the motor and ESC are sensored!
Does this mean I can only run 4s?
Like I said, apparently some folks run it on 6s, and I would too. And buy a sensor wire if one isn't present. Sensored is smoooOOOoooth.
