I never seen one before on the All Road 1/8 line 4x4's. Looks like the F/R T2T mounts are there however.
I checked the blow up diagram, I don't see it. The Chassis length is unique to these if I am correct.
Not sure if you can use one from the 4s 4x4 chassis'. Maybe. May just need some trimmig to length IDK..
Do you really need it anyway?
You are not sending it 20 feet up, are you?
Perhaps an Upgrade brand has them? Below is for the Kraton 4s 4x4 chassis. It is longer than the OC 4s 4x4 chassis. Check what size you need. Get the longer one. To Trim down. I doubt that both of these will be a drop in or plug and play. I could be wrong.
But it can be fitted with some trimming.
https://jennysrc.com/collections/kr...n-4s-4x4-red-center-brace-bar-265mm-ara4408v2
FollowingHi there I’m after the Centre brace for my 3 s infraction blx but can’t find the pet number or where to buy from thanks for
