- Panhandle FL
- Mojave EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
- Voltage
I want to answer a question I’ve seen asked a few times here, but no one seems to know the honest answer. This is for torque spec heads that live and die by the torque wrench.
On Arrma 17mm wheel hexs, the torque spec is between 90 to 100 in/lbs (5.625 to 6.25 ft/lbs). Since there’s no official spec from Arrma (that I can find) I did a little testing myself. By using a very accurate torque wrench (Project Farm approved) on 3 brand new Arrma models never used and their wheels have never been removed. All took around 100 in/lbs to remove initially, non had any thread locker from the factory. After torquing the hex to 90 in/lbs, the hub and wheel nut have the same depth as they did from the factory.
I'm sort of a torque spec head myself and hope this helps; cheers!
