- Kraton 6s
- Kraton EXB
- Thread starter
- #21
Got my center dog bones installed and my shock stand offs on my m2c balls the standoffs worked perfectly on the m2c plastic shock balls they all were consistent tight threaded high precision beautiful finish and tightened no problems the center dog bones fit perfectly are a touch bigger along the narrow side but fit beautifully I used rubber orings to eliminate play the front was to tight with one in the rear was 2 tight with 2 in so I used 1 all and all beautiful quality and the price can't be beat is on par with any of the other companies if not better
Also I wanted to try the ramjam 4140 input cup on the rear of this to see how they compared to the scorched that I deformed but I ordered the wrong one my fault not ramjams I since ordered the right ones but the ones I did receive are beautiful I have since ordered the proper parts
Also this is why I did the plastic shock ball and stand off kits with the stock rubber bushings it hammered the shock caps now it shouldn't and it took up all my shock play and if I was replacing the balls I might as well fix it right the first timeGot my center dog bones installed and my shock stand offs on my m2c balls the standoffs worked perfectly on the m2c plastic shock balls they all were consistent tight threaded high precision beautiful finish and tightened no problems the center dog bones fit perfectly are a touch bigger along the narrow side but fit beautifully I used rubber orings to eliminate play the front was to tight with one in the rear was 2 tight with 2 in so I used 1 all and all beautiful quality and the price can't be beat is on par with any of the other companies if not better
