Will 1480kv motor run cooler @ same speed?
ho lee chit
Netherlands
  2. Notorious
  3. Outcast 6s
I don't like the noise of the fans I have on my kraton.
On my notorious v4 motor gets pretty hot on 4s with 14t pinion. And yes I drive it like I stole it.
A 1480kv motor with a 19t pinion should give me the same speed. Question is, will it run cooler? And will it drive the same? That is, with the stick blx185
Thanks Jerry-rigged, I forgot to mention that I now have the stock blx 2050kv 6s motor.
I was looking at the 4092 1480kv motor or the 4082 1600kv motors for lower temperatures with same top speed as the original blx motor
No don't do it I’ve had bad luck with 1600kv and 2000kv motors from hobby star. Both would over heat The 2000kv was fast and the 1600kv was just slow I had a 21t pinion on it. I think the 4092 1730kv motor is the one to get
