if its a stock kraton 8s exb rtr I put a 26t on mine and runs great think stock is 23tMy buddy has this question he does not know English but I'm trying to help him. he ask is a 32 to 34 piñion ok?
think you get a 30t pinion in the box. heard a few say 28t is the best but like you said it gets a bit warm with a 26t so 28t seems a bit much unless you put better fans on the motor and esc.I went from 23 to 26t (and 47t stock spur) on my K8S with the 1100 kv Firma motor, runs great, gets a bit warm for my use. I'll likely have to drop it back down a tooth or two once summer gets here. Depends greatly on how/where you use it and what tires you run.. I definitely agree that a temp gun is very valuable to have.
IDK what the biggest pinion that fits is, but do know that to go much bigger than my current 26t, I would definitely have to change out the spur. My motor mount doesn't have much more adjustment left currently.
I see. TBH, I didn't get any alternate gears with mine since I bought a v1 rtr K8S. It came with a 23t pinion, 1250kv 4685 motor. Wierd part though is that the original v1 K8S rtr came with a 17t pinion, same motor.. talk about slow, I couldn't imagine how anemic that must have been. LOLthink you get a 30t pinion in the box. heard a few say 28t is the best but like you said it gets a bit warm with a 26t so 28t seems a bit much unless you put better fans on the motor and esc.
