vorteks maniac
- Vorteks
I’m looking for a cheap good 10000mah 3s Lipo
For what kind of driving?Best
Best
Bashing, I’m driving an Arrma vorteksFor what kind of driving?
CNHL makes good packs too. But I agree 100%. If you want longer run times get 2 5000mah packs instead of 1 10,000mah pack.I’d recommend an SMC battery about 5000mah. A 10000mah battery would be way too heavy.
I've heard smc gensacearespammers are the top notch onesAll the ones on Amazon are coming from the same source (multiple companies) as they are the lowest grade that better brands won't take.
Literally makes no difference what name is attached, it's just a printed sticker.
There is a small chance that you get lucky but usually they are all in the real 15-30C range and about 80% of advertised capacity. This is a very general statement.
You get what you pay for.
For bashing you want something that will last a season at reasonable run time. One Zee/Hovoo/ etc is about 1/3 of an SMC in capacity but I wouldn't use my SMC in a basher, hard landings are not beneficial to life.
If you don't jump use Gens, CNHL or SMC. If you jump, get something cheap and pray. Buy 2 or 3ea. and it should work just fine.
Duracell
I'll second the CNHL recommendation. I started with a bunch of Zeees because of Black Friday deals, but I wish I had done CNHL instead.CNHL makes good packs too. But I agree 100%. If you want longer run times get 2 5000mah packs instead of 1 10,000mah pack.
