teacherkurt
New Member
Does anyone have any reasonably priced servo upgrade recommendations?
Thanks.I run this one. Super fast and a lot more torque than stock.
https://www.amainhobbies.com/no-sup...P5GJWdGdjw8lZeHceX6Oo7X6WRCPBhMwaApGLEALw_wcB
Just an aluminum servo horn. With the metal gears, something plastic would break long before stripping the servo.Thanks.
Did you use the stock servo saver, something else, or nothing at all?
I can also use the BEC that CC provides too right? I want to get the 1010 combo but I don’t want to do the EXT BEC they can put a INT BEC but it can only go up to 2Amp and with the external up to 10Amps. What do you think I should do?I also use the same servo in my typhon grom, with no saver, and it's excellent. The car drives dead straight at any speed! You may also want to get the nano BEC because this servo can take up to 8.4v and most micro ESC are only 6.0V or at most 7.4V.
https://nsdrcscaleparts.com/collect...oducts/nsdrc-micro-bec?variant=40163106128007
