typhon 3s grp tires rubbing??
arrma 43
  1. BigRock 4x4
  2. Typhon 3s
when using grp belted onroad buggy tires for typhon 3s , noticed they are not wide enough and rub on the steering rods on typhon, will use a offset hex 10mm, but have you had this problem??
Same thing on my 3s typhon but a very small amount. My wheels spin by hand fine so I run them. not sure how bad your problem is.
hi! yes my fronts rub on steering arm. got some 10mm offset red hexes from china, wish they made 5mm offset, but will try it! grp make there rimes smaller than china ones I use on my typhon, they fit no problem but these rub a litttle!
