thx for advice ( ´∀` )bI had run this same setup in the past and its great!
Before going fast I would get your toe angle adjusted. The toe out like you have it is ideal for quick turn in, but not good for high speeds.
"Generally the rule of thumb is that more toe-in increases understeer and more toe-out increases oversteer. However, with modern cars, especially race cars with independent front and rear suspensions, there is another effect on handling. Most manufacturers recommend a chassis alignment which contains a small amount of toe-in. This will give the best possible stability at speed"
