Senton 3s blx question
FastMann40
Military Veteran
West Coast Ca
  1. Senton 3s
  2. Typhon 6s
I recently bought the Senton 3s BLX, and I am not sure if it's normal for the rear end to be so low, but is there a recommended solution to raise the rear suspension a bit so it runs more level? Is this a spring/shock length issue? Do I get lengthen a arms to help with this?
Thanks in advance.
If your ride height is sitting low you can add preload spacers to the shocks and raise it up.
If you bought your truck new it should have came with the spacers?
It was used and the previous owner said he used it 5-6 times, although the body and axle hubs suggest different. 😉 I'll look into the spacers. Thanks
Every Arrma vehicle has an exploded view that you can use to figure out what parts you need. In this case you need shock spacers. to increase the preload on the spring to raise the ride height.
Granted the spacers are kind of hard to pick out from the exploded view.
Exploded view:
https://www.arrma-rc.com/en/interactive-exploded-view?pid=ARA4303V3T2
Spacers:
https://www.arrma-rc.com/en/product/composite-shock-parts-o-ring-set-2-shocks/ARAC8940.html
You can also click on "replacement parts" or "optional parts" from the vehicle web page to try to find the parts you need.
