Spackle-king
I'm sorry, I know this topic has been discussed to death, but with 10 pages of search results for "felony rear diff", I'm having trouble finding the correct part number. On Amazon, the Arrma part listings are the most vague generic, unhelpful and sparse. I want to get a rear diff that is geared like the front, so I can (like every felony owner wants) run the same size tires in back.
https://www.amazon.com/ARRMA-Front-...6986&sprefix=felony+front+diff,aps,193&sr=8-3
That is what I see on Amazon, but it says "front or rear diff", which doesn't make a lot of sense, seeing as they are differently geared. I'm wondering if that is the diff I will need to put in the rear to be able to run smaller diameter tires.
And I know this is discussed a lot, but I am not experienced enough to do gear ratio math myself.
If I get a correct front diff and pop it in the rear, is that *all* I will need, gearing wise, or is there another gear I'll need to replace as well ?
I looked in the manual, and it appears the front diff is the ARA311023, which is the Amazon listing above, but before I pull the trigger, I'd like to know any other parts I may need. I've seen people talk about the Kraton wheel hubs to make the wheels farther out, to line up with the body shell, but that's cosmetic to me, and less important. I'm worried about proper gear ratio today![Thinking face :thinking: 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Thanks in advance.
![Backhand index pointing up: medium skin tone :point_up_2_tone3: 👆🏽](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f446-1f3fd.png)
Thanks in advance.
