IvanRC
What is the most optional mm setting for your Front and Rear Shock Collars?
Thank you for the feedback. The only specific mm numbers I have been able to get is from ARRMA for an 8s which they say 5mm in the front and 7.5 in the rear. Do you know what you run so I can try that set up.Hmm.
I set my shock collars on two specifics for me. Most importantly, how I want the rig to rebound back under bashing/performance. This also plays with the diff fluid weight in the shocks.
Other is the rig ride height. If possible, I like my rigs to have a slant to the front so it rides levels or level under power.
Adjustments are subjective and personal.
I can give you my settings and you might hate them. Or you can figure out what settings you like best for your terrain and driving style.What is the most optional mm setting for your Front and Rear Shock Collars?
That is set by the droop screws, not the shock preload.I like my a-arms parallel to the ground
droop screws = lazy man's shock tuningThat is set by the droop screws, not the shock preload.
Droop screws = rod shock ends lasting more than the first big senddroop screws = lazy man's shock tuning
[removed more drunk ramblings.........]
same as proper fluid/spring weight, internal/external limiters, etc, but you feel free to do/think what you want.Droop screws = rod shock ends lasting more than the first big send
Thank you for the info and great pics. Where do you get those cool spring covers and protective rear mud flaps.Hard to get a good pic with one hand. I am about stock, maybe some minor adjustments, if any at all. I am measuring from where the ruler is sitting to the bottom of the black cap:
front 19mm
rear 16mm
Front
Rear harder pic is at an slant but 16mm what I have
No. Droop screws limit maximum suspension travel. Shock collars set ride height.That is set by the droop screws, not the shock preload.
There it is...No. Droop screws limit maximum suspension travel. Shock collars set ride height.
Covers hereThank you for the info and great pics. Where do you get those cool spring covers and protective rear mud flaps.
There it is...![]()
The droop screws establish just that; the amount of "droop" allowed before the suspension comes to a mechanical stop. Think of them like limiter straps on the long-travel truck's suspension. They prevent any further motion downwards to solve two distinctly different issues: 1, the desired amount of suspension travel downwards in relation to the surface you are driving on ( we have quite a bit of travel for our rough desert track ). 2, preventing damage to other suspension components or drivetrain components due to over-travel.Interesting, that is different to what I had been told.
I have been setting it up with parallel arms via the droop screws, what should I be doing?
Steve B,The droop screws establish just that; the amount of "droop" allowed before the suspension comes to a mechanical stop. Think of them like limiter straps on the long-travel truck's suspension. They prevent any further motion downwards to solve two distinctly different issues: 1, the desired amount of suspension travel downwards in relation to the surface you are driving on ( we have quite a bit of travel for our rough desert track ). 2, preventing damage to other suspension components or drivetrain components due to over-travel.
I do not like my shocks to be the stopping point on either direction of suspension travel. The bottom of the chassis smacks the ground when I fully bottom out ( on my 1/8 Tekno ) and the droop screws limit of far down the lower A-Arm will rotate around the pin attaching it to the bulkhead. Unfortunately for this particular rock racer, the Lasernut, the original buggy setup was never intended to run a tire height as tall as this 2.2" wheel and 5.5" Axial Ripsaw tire combo, so what I really need here are bump stops for the upper travel. I just haven't figured out a way to install a set.
This has nothing to do with the spring setting ride height. And if you are stacking tons of spacers to get the right ride height, you need to change out the springs.
Droop screws in action.View attachment 284201
