- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
I'm all about suspension swaps an building unusual trucks.MOJAVE SUSPENSION IS THE STRONGEST OF THE SMALLER ARMS.NOT 100% ON THE TYPHON ARM SIZE ,FEAL FREE TO CHIME IN ON.so senton6 arm shortest,typhon arm,Mojave arms ,then of course the kraton, noto,OC arms being longest.for going with the shortest Mojave arms you must do a little dremel work to fit.here is my noto with mojave suspension.THE EARS ON ARMS ARE SHAPED DIFFERENT,REMOVEING A LITTLE MATERAIL OF THE ARM iS EASY AN IVE HAD NO PROBLEMS WITH IT.HIT A PAVILION POST HARD AT PARK EXPECTING DAMAGE ,NOPE .left a nice bruise, NO BREAKAGE!!!MY NOTO HAS TAKEN SOME SERIOUS TUMBLES AN IMPACTS,TRUCK IS SUPER STRONG. REMOVE A LITTLE MATERIAL SO BOTTOM OF ARM CAN CLEAR TAB LIKE THIS.
Shrinked noto WHEELIES less an stays planted a little better.still a crazy truck that'll still cartwheel 75feet ..so must be careful,it'll just keep cartwheeling if crash conditions are just right
That's senton6, Mojave arms.parts truck outcast an noto with mo suspension bottom picI'm all about suspension swaps an building unusual trucks.MOJAVE SUSPENSION IS THE STRONGEST OF THE SMALLER ARMS.NOT 100% ON THE TYPHON ARM SIZE ,FEAL FREE TO CHIME IN ON.so senton6 arm shortest,typhon arm,Mojave arms ,then of course the kraton, noto,OC arms being longest.for going with the shortest Mojave arms you must do a little dremel work to fit.here is my noto with mojave suspension.THE EARS ON CHASSIS ARE SHAPED DIFFERENT,REMOVEING A LITTLE MATERAIL OF THE ARM iS EASY AN IVE HAD NO PROBLEMS WITH IT.HIT A PAVILION POST HARD AT PARK EXPECTING DAMAGE ,NOPE .left a nice bruise, NO BREAKAGE!!!MY NOTO HAS TAKEN SOME SERIOUS TUMBLES AN IMPACTS,TRUCK IS SUPER STRONG. REMOVE A LITTLE MATERIAL SO BOTTOM OF ARM CAN CLEAR TAB LIKE THIS.
That's senton6, Mojave arms.parts truck outcast an noto with mo suspension bottom pic @SKUNKWORK SCI'm all about suspension swaps an building unusual trucks.MOJAVE SUSPENSION IS THE STRONGEST OF THE SMALLER ARMS.NOT 100% ON THE TYPHON ARM SIZE ,FEAL FREE TO CHIME IN ON.so senton6 arm shortest,typhon arm,Mojave arms ,then of course the kraton, noto,OC arms being longest.for going with the shortest Mojave arms you must do a little dremel work to fit.here is my noto with mojave suspension.THE EARS ON CHASSIS ARE SHAPED DIFFERENT,REMOVEING A LITTLE MATERAIL OF THE ARM iS EASY AN IVE HAD NO PROBLEMS WITH IT.HIT A PAVILION POST HARD AT PARK EXPECTING DAMAGE ,NOPE .left a nice bruise, NO BREAKAGE!!!MY NOTO HAS TAKEN SOME SERIOUS TUMBLES AN IMPACTS,TRUCK IS SUPER STRONG. REMOVE A LITTLE MATERIAL SO BOTTOM OF ARM CAN CLEAR TAB LIKE THIS.
