MMX8s limits
I had the 4050CM 2300KV in a Senton on both 6S and 8S with the MMX8S and it was awesome. You shouldn't have any problems as long as you gear for the surface you're gonna run on. I'd only use that higher KV for on road use but that motor with an MMX8S is a killer combo especially since its so lightweight. You can bash it, drag it or do light speed running depending on your gearing and usage.
