So I've gotten a TON of help from you guys in my intro thread with my Kraton 6s EXB. I'm grateful for your advice and will be doing build threads on both it and the Infraction once I get my orders in.
The Infraction has been kind of set to the side in conversation so I wanted to start this thread for it so I can keep the info separate. It is a V2 6s that had been converted to 8s (and undoubtedly abused).
I'm waiting on suspension parts to repair and I ordered a MMX with the 1717-1650. I want to set it up for pretty hard street bashing but be able to simply change the pinion (if possible) for speed runs, obviously all the while keeping it from frying. I need to mention I suspect PO replaced the spur but I have the OG and it looks fine. I also want to mention I'm not afraid to order a new spur at the recommendation from you fine gentlemen. What fluids should I use?
If you bought one of these used and had suspicion of abuse what things would you look at closely? Chassis upgrades? Suspension upgrades? Different body available? If a tree falls and nobody is around to hear it, does it still make a noise?What exactly is that little umbrella in the drink supposed to do?
