- Granite
So I got the new 4s center diff for my Granite, but looks like it won’t fit a swb chassis. There is barely enough space for the motor to clear the receiver box. But you still need more space to slide the power module in and out.
You could make it work if you removed the receiver box every time you needed to slide the power module in or out. That’s a huge PITA.
You could maybe Dremel out the sliding rails for the power module and just drop it straight down. I’m not even sure this works. But even then your entire power module/ center diff would be hanging on with 2 screws fastened to plastic. I think it might not last a single big jump.
If anyone has found a way to make the center diff fit and work reliably on a SWB chassis, please let me know.
