Arrma Screw Part Numbering
Relimar
MA
  1. Typhon 6s
Been building up my Typhon to Infraction parts car, and have basically figured out Arrma's Part Numbering scheme for basic screws:
AR72 - all screws prefix
Next digit is the head type:
1= button head
2= flat head
3= cap head
4= set screw
Next digit is metric diameter:
2=M2
3= M3
4= M4 etc
Last two digits are length
10, 12, 16 etc
Example: AR722312:
AR72=screw, 2=flat head, 3=M3, 12=12mm
M3x12mm flat head
That’s brilliant mate, do you know if you can get a full nut, bolt and screw set in a kit or do you have to get them all individually?
I've only seen all needed hardware together when it's some specific component, infraction e-brake etc. Otherwise all individual, tiny packages of screws.
I found bulk M3 & M4 nylon lock nuts on Amazon and bulk alloy black oxide on McMaster, but they rust quicker than oem Arrma
Not as cost effective for you being in the UK, but Jenny’s RC sells complete model specific sets that were takeoffs. Have you tried Bad Touch Breakers? They’re in the UK, right?
You do realize that this information is already in a sticky at the top of this section right? https://www.arrmaforum.com/threads/arrma-screw-part-number-decoder-mostly.59847/
Victor Rasuk Romance GIF by ABC Network
I’ve just checked out bad touch, they don’t seem to have a website, only social media pages which I won’t participate in unfortunately.
I mite order some from jennys, there’s a few bits I could do with that are out of stock over here. 👍🏼
