Kraton 2nd bash with a brand new K4S v2.5! My heart is bleeding :D
Barmaleus
Tallinn, Estonia
  1. Kraton 4s
Good evening!
Welp, I tried to be careful. But alas.
The car was doing a lot of km/h, my face had a silly smile and hands were chilly (around +2C here in Estonia). Next thing I remember - Kraton is roughly 50-60m away from me, I am doing a left turn and BAM! The car spins and I see its right front lifelessly lying on the ground. I take my finger off the throttle and realize I'll have to discharge almost two full 6600mah batteries this evening.
*Sigh*
I KNEW that a steel post was there, but miscalculated the distance between it and the Kraton. And its speed.
So far it looks like I need:
- New body ( :cry: just its second bash... RIP, dear). I wonder why bodies are not modular?
- Aluminum suspension mount
- Hinge pin
- Front suspension arm
- Shock cap
- Front skidplate
Need to test:
- Front shock. Hopefully the rod is not bent (upd: is OK)
- Servo. Hopefully alive (upd: is OK)
Maybe other hidden damage I have not discovered yet (upd: rest seems to be OK)
Anyway. Lick clean the wounds, charge the batteries and off to a new bash. Soon, hopefully :)
Those damn steel poles. Always in the way. I hit a soccer goal post with one of my JLB Cheetahs once. It came back across the field with the wheel flapping from side to side. Bummer. But, a few new parts later, and it was back out there again. Such is life in the fast lane...
Amen =)
Good evening!
*Sigh*
- Hinge pin
- Shock cap
Need to test:
- Front shock. Hopefully the rod is not bent.
- Servo. Hopefully alive.
Maybe other hidden damage I have not discovered yet.
Save those busted Chassis!
Those can be salvaged in the right hands.. 💥👊😉
*sigh*
No party today. The skidplate was also broken, but I did not realize that. Need to order it as well. Ehhhhh, bummer.
Crawler today then.
It doesn't look too broken.... I would rebuild and use as is until you get the new one, unless there is something I am not seeing.
@Saladshooter Ehh, I don't want risking a torn-out pin again :( The way it is now - looks fragile. I found a skid plate locally, so hopefully all will be in order tomorrow :)
I understand and just trying to help. 60 degrees Fahrenheit here and sunny today.... rain the rest of the week so I wouldn't want to miss out on a day of driving.
If all screws are still intact I don't think it's in any more danger of a pin tearing out than with a new skid plate.... but with only one day to wait it's not a big deal.
