- USA, Georgia
- Gorgon
- Infraction
- Kraton 6s
- Notorious
- Senton 3s
- Infraction 4x4
I have soldered the EC5 to my ESC wires using a 100/110w Weller soldering gun. I pre fit the stripped wires into the bullets. Then pre tin the wires & bullets. Then heat the bullets w the gun having the soldering wire ready, the pre tinned bullets get hot, I insert the stripped wire, then finish off w the solder wire. I also heat the gun tip 'dry' Then add the wire to the tip then put it to the bullets to fill any voids. It's like the opposite of TIG welding.
I also use wooden clothes pins to help hold everything, the wires & such. And needle nose pliers, it gets hot
