- USA, Georgia
- Gorgon
- Infraction
- Kraton 6s
- Notorious
- Senton 3s
- Infraction 4x4
It's the high wing mount, yes.That's the one, I think I'm gonna order the high profile kraton one eventually.
Always a trade-off between linger run times and heavier rig (more breaking)!Hello guys,
long time since i have run a 6S rig, do you think 6S 5000/75C is sufficient for this new Kraton or do i need something bigger like 2X3 6800 120C,
Thank you
For 6s a single 6000mAh or a little larger should do fine. Keep your trucks as light as possible for more performance and less wrenching. If you need longer run times, carry another battery. It only takes a minute to switch them out.Hello guys,
Thank you
Depends on the brand more than anything. 5000mah 75c Amazon cheapos are not going to cut it.Hello guys,
Thank you
It only works for the V1 EXB, not the new one. I emailed the 3DRC guy to ask about making a new version but never got a response.That's the one, I think I'm gonna order the high profile kraton one eventually.
It'll fit Bruce's K6It only works for the V1 EXB, not the new one. I emailed the 3DRC guy to ask about making a new version but never got a response.
For real!And the new Outcast where is it
Just to follow up on this, I ordered the high profile wing mount from 3DRC and asked about fitment. He responded:It only works for the V1 EXB, not the new one. I emailed the 3DRC guy to ask about making a new version but never got a response.
Well right now across Amazon, CNHL, and Ebay there is a 20% off spring sale going on right now, so if you are to buy batteries I would suggest you get them now.. There won't be another good discount like this until probably the 4th of July..Hello guys,
Thank you
Hi bud did you ever get to try the new exb v2 braces on the v5 I’m wondering the exact same thingWonder if all new parts will fit v5 and v1 exbs
Looks like the new chassis braces have 2 screws from bottom now now And inserts
Thinking these won’t be compatible with older models
