Snacktime
- Gorgon
So for a grand total of $246.64 I have bough my first 3S Arrma Truck or is it Mega? Very little chassis scapes, some cool lights and MAX 10 system!
Ebay photos
Lists of parts on truck:
-Hobbywing Max10 G2 combo
-Surpass 30x30mm ESC fan
-Surpass Motor Fan with Heatsink
-18t pinion
-53t spur slip eliminator clutch
-ARRMA Power Module & Metal Slipper Boost Box
-diff case front&rear 17t pinion/ 47t spur
-Spektrum Sports5channel receiver
-steering Servo Protek rc 140S
-10 amp Castle B.E.C(remaps receiver to push out max allotted voltage to the plugged in parts)
-RPM Front and Rear A-Arms
-ARRMA CVD Slider Rear Set
-Proline StreetFighter tires (about 70% of tread life left)
-Aluminum Hot Racing 12mm Hex’s
-All adjustable camber & steering linkage
-Hot Racing Progressive Rate Front spring(medium-black)
-Hot Racing Progressive Rate Rear spring(soft-chrome)
-Proline front white light bar
-INJORA rear red lights
-traxxas roof skid plate
-Fast Eddy Bearings(complete bearing swap)
-e-flite light controller( depending on your remote, it’s used to turn the lights on and off. Or they’ll just stay on)
List of parts included in this lot:
-Original operators manual
-carrying backpack(used to store or transport RC)
-hobbywing LCD programmer
-Spektrum g2 2s 5000mAh 30C lipo battery
-GoldBat 3s 5200mAh 80C lipo battery
-Set of stock Arrma deboot tires( 95% tread life left)
-Set of stock Arrma aluminum 14mm hex w/ pins
-Hot Racing Progressive Rate Front&Rear Spring Set(Gold,Black,chrome)
-1 extra rear shock assembly
-1 extra front shock assembly
-Extra pair of body mounts
-full set of stock composite steering and camber buckles
-Extra Pair of Mud Guards
-three full sets of plastic shock spacers
-castle 550 motor cooling Shrout
-Stock rear Arrma a-arms
-stock diff front and rear case/pinion
-proline wheel adapters for a smaller offset
-a small bag of body clips
-stock servo saver
-stock 15t pinion
-Arrma 57t Metal Slipper clutch
-stock servo Spektrum S650
-Stock Arrma ESC
-Stock ARRMA Power Module
I mean all the signs say good buy. I mean it comes with some cool freebies I would never spend money on.
Ebay photos
-18t pinion
-stock servo saver
-stock 15t pinion
-Stock Arrma ESC
