Dan B.
Area man
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- Southern Vermont
- Fireteam
- Granite
- Limitless
- Mojave EXB
- Notorious
- Outcast 6s
- Typhon 6s
I’m in the middle of a very high end, meticulous build right now and I bought the Perfect Pass a-arm kit to install because they have what I feel is a great design for potential aerodynamic gains, as the flat bottom of the arms could really reduce turbulence, and that’s one of the features Raz markets them on. I watched his video highlighting the precise machining processes he employs to reduce slop and play and make an arm that precisely fits the hinge pins and blocks to create a precision suspension setup whose geometry doesn’t deviate a few degrees while running.
Mine suck. And I need to say that again…mine suck! Sorry if that’s unkind, but they are sloppier than several “chinesium” sets I’ve purchased in the past, don’t even come close to Vitavon, and in fact don’t even come close to the factory Arrma plastic a-arms. Super freaking disappointing.
I’m pulling them off and may sell them if I can resist the temptation to throw them in the freaking trash.
After installation, it was clear the bores were significantly too large for the hinge pins. The proper line-bore was also seemingly a point of pride in his release video, with him stating that it was perfect and far superior to other offerings with no slop whatsoever. I was trying to measure the deviation as much as possible (hard while installed) but my angle gauge came up with over 1.5° of movement (measured laterally with front to rear deviation) when moving the arms front to rear on the hinge pins.
In addition, the distance (SLOP) between the front and rear lower blocks is totally unacceptable. Again, I’m going for as close to perfect as possible on this build and have gone to great lengths to achieve that. They can be slid back and forth a fair bit. Not enough to insert a 0.20 PTFE shim in there, but close. So, I could file the ends of the arms and fit shims to make it perfect. But I’m not doing that, especially in light of how “perfect” these were marketed to be, and how much slop there is in the hinge pin bores which is something I can’t do anything about.
If I had to guess, I’d say that when Shifrin was setting up for production in China that the prototypes he was sent, the ones featured in his launch video, were made properly by one of their ISO facilities and when it came time for actual retail production they went to some substandard factory out in what China passes for the Boondocks. No wonder he’s offering them so much more cheaply than other “quality” choices in the RC market. The machining is less than impressive as well, with a few burrs present on the machined edges.
I’m so disappointed, and actually pretty pi$$ed at myself for ordering them in the first place after sh’tcanning his alloy body mounts three weeks ago from my last purchase. Those were so sloppy that the body posts pivoted 2mm in each direction, plus the set screw on the sides were small, soft stainless Phillips head screws.
I’m done throwing money at Perfect Pass at this point. I’ve bought better quality for far less money from GPM, Hot Racing, and even Integy and no-name AliExpress offerings!
This is the second Perfect Pass machined aluminum product I’ve purchased, and the last.
I have a set of quality Vitavon arms on the way now to replace this garbage. What I should have done in the first place, based on years of receiving the best billet components in the RC world from Vitavon. I really believed Raz had made a better mousetrap here, but was sadly mistaken.
