Gorgon NEW GPM 7075 Servo Saver
BigP
I just found this new servo saver for the Arrma Gorgon. Stock one seems to be a weak spot. Has anyone tried this GPM Servo Saver?
Actually yes, I put that exact GPM one in my brushless Gorgon. I thought the stock saver had broken, so I got that GPM one. The saver was in fact nearly broken, but my problem was the servo itself. I took it all out, & I could spin the servo all the way around, not much resistance. It had stripped, but not fully. So you might consider replacing both. The GPM saver is great though. Well machined & fit right.
Here's some pics. Hope this helps.
I went with a Power HD 23kg servo. I had to file about 0.020" off the hat of the servo to get it in the chassis. Equal amounts each side. It's a tight fit in the chassis where it mounts into, but it fits secure & snug. No movement.
