- Limitless
- Thread starter
- #61
Finally got around to setting up the shocks with nitro tubing and nylon spacers in the front, as well as cutting down the front and rear spoilers for aero.
Rear all set up:
For the fronts, I inserted nylon spacers on the shaft inside the shock body in order to lower the front end:
Here, you can see the difference; vehicle left side is shock with nylon spacer inside, vehicle right side is regular with no spacer...you can see how it brings the arm up and lowers the stance of the front end:
Front done:
Aero done:
How it sits now, notice the front end is lower; also, suspension in rear will not squat below the front end level:
Waiting for the batteries to charge, might not have enough daylight to do a pass.
Rear all set up:
Front done:
Aero done:
