- Kraton 4s
- Outcast 4s
- Outcast EXB
- Talion EXB
So, I have done a bunch to my Granite BLX, including RPM Typhon arms, and a Mamba X with 2400kv setup.
Snapped rear U-joint first pack few weeks ago. I don't like weak parts.
Ordered the Arrma CVD axles. Got them...they are too short for Typhon arms. They are actually shorter than stock. Odd. The slider will only slide in about 1/2 inch. Nope...didn't even install them.
Did some research and came up with an idea...and just finished 2 of them.
The Kraton/OC 4s has optional CVD also. But they are too long and the ball ends are larger than the 3s CVDs. Ended up using 1/2 of the 4s CVD, this the 4s outlive cup and pins, and the other end of the 3s CVD slides in. Had to trim the length of the 4s slider...but it is perfect....and MUCH more stout now. Also the 4s outdrive cups are all steel. Nice. Some pics with the stock and the 3s CVD for comparison.
Here is all the parts to make one. Right is the lower part of the 3s CVD. Other parts are the 4s.
here is length comparison of 3s and 4s slider. Also see the smaller ball of the 3s.
Here is a trimmed 4s compared to the stock before trimming.
Here is a comparison of my hybrid CVD, 3s CVD and stock driveshaft.
Here is a length comparison of the 2 hybrids I made, and the stock. Stock is stretched to where it was with Typhon arms. As you see the hybrids are barely extended. Should be pretty tough.
