- Notorious
- Talion
- Typhon 6s
Anybody here use red loctite on certain parts that you hardly ever take off? I know it requires a good bit of heat to loosen, but I'm wondering if a very small amount could be effective while still not being too difficult to remove.
I have a 2wd rig that I have 17mm hex adapters that use a barrel nut to hold them in. If it gets tightened too much, it puts pressure on the hub bearing and wears it out fast. If I don't tighten down hard, blue loctite helps it stay longer but not enough to keep it from loosing a wheel at times. I was thinking of using a small amount of red loctite on the barrel nuts on the last few threads. Figure it might be just the right amount of strength for what I need, worst case scenario I can remove the hub and heat it up to remove since its aluminum.
Anybody else use red threadlocker on their rigs?
