- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
+ its toxic
I got a Max6 G2 4990 combo from Amain for $235. I do have a Weller 140 watt soldering iron & it wasn't too bad putting a EC5 on it.OK, You guys got me convinced with the Max8 Combo.. and it's waterproof compared to the ZTW.
And thank you for the promocode as well to take the price down a notch
True, However the Max 6 doesn't come with pre-soldered connections.. I don't have a soldering set, no close LHS's either to get it done.. It's a great set and I'll be primarily running 4S most of the time. Occasionally 6S just for kicks.
Sweet!! Congrats!Thank you all for all the good advice and steering me in the right direction.. Purchase made..
Yep, .5mm difference in bullet size.. it matters, and they will melt..Female EC5 will plug into Male XT90 but it'll be a hot dog down a hallway when warm.
Never knew nor ever thought to look at that! THANK YOU for that valuable information!Sweet!! Congrats!
FYI most any bullet connector is adjustable, such as EC, XT, ect. Just close or open the male side of the connectors till you achieve the desired tension. See the split in the male pins below. Small flat blade to open and make the connection tighter, needle nose pliers to pinch them closer to loosen the fit.
Also, I solder up to 10ga wire with a 40 watt Weller, paid $25 for it. Mint!
Hey, I've spent my fair share of time wrestling connectors apart over the years too, trust me. Then one day someone here shared this priceless info and, BAM!! No more struggling!! Who knew?! Arrma Forum, that's who!!Never knew nor ever thought to look at that! THANK YOU for that valuable information!
well that does bring up a good question.. I sent them another contact email.. hoping for an answer pretty quickly like last time in regards to your post..It might include the connector but it is not pre soldered. I'm pretty sure op is going to have a bad day once that package arrives. I've ordered 2 esc from hobbywing directly and neither came pre soldered
You should have ordered it from the link I posted if you didn't want to solder. If I were you I would cancel that order.
tbh i'm surprised no one else pointed this out
I'd solder it for you if you were close. Maybe you can work it all out.well that does bring up a good question.. I sent them another contact email.. hoping for an answer pretty quickly like last time in regards to your post..
Well luckily I received email reply from HW.. With the combo, the XT90s are pre soldered, same as the YouTube video shows. If buying the esc as a single unit then not.I'd solder it for you if you were close. Maybe you can work it all out.
ahhhh that is good to know. I did in fact only buy the esc's as a single unit and not a combo. Enjoy your new electronics bro!Well luckily I received email reply from HW.. With the combo, the XT90s are pre soldered, same as the YouTube video shows. If buying the esc as a single unit then not.
